cairus
1,928
739
So that's the next project.
The starting point is this:
Skoda Kodiaq, model year 2019
PR code for SBBR light: 8SK
BCM:
HW 5Q0937086BR
HW version 036
SW 5Q0937086BR
SW version 0265
Target:
Skoda Kodiaq, model year 2021, facelift
SBBR light part number
565945207B
565945208B
565945308F
565945307E
This requires rerouting the cables in the tailgate.
I still need to check the BCM software version to see if it needs to be updated.
As for the animation, the BCM definitely needs to be replaced, but it's not necessary.
Unfortunately, I had to process the information that the facelift was more modified than expected at the rear.....
that means the new upper part of the bumper is needed as well as various other things unfortunately...
the following parts are only needed for the conversion so that the facelift taillights are properly installed:
565807421B — Upper Bumper Section
565945105B — Left Reflector
565945106B — Right Reflector
565807393C — Left Bumper Guide (Small)
565807394C — Right Bumper Guide (Small)
565807393D — Left Bumper Guide 565807394D — Right Bumper Guide
565907455D — Left Blind Spot Radar Bracket
565907456D — Right Blind Spot Radar Bracket
565807863A — Bar with Clamps (Center Bumper Bracket)
565945207B — Left Taillight
565945208B — Right Taillight
565945307E — Left Taillight inside
565945308F — Right taillight inside
565945311 — Left taillight cover
565945312 — Right taillight cover
The complete retrofit will cost us around €1,000. Everything was rebuilt and coded by ourselves, of course.
First Material
The next parts for the conversion are arriving...
It's currently in progress. Received the next parts today. The taillight set is now complete. The connection pins and the connectors for the adapters have also been delivered.
Also, hier ist die Sache:
Der Facelift-Stoßfängerbereich erhält einen frischen Anstrich.
Ich habe heute die letzten Teile für den Umbau abgeholt.
Reactions: Heijd1973
Left inside Adapter
All 4...
Oudside 4 To 8
Inside 3 To 8
I want to connect the original connector to the outside. So, I'll use a 4-pin to 8-pin adapter, and use this connection to pick up the signals needed inside. The same thing happens inside, of course.
The Next one...
If you have the 5Q control units, they won't fit in the 2Q mount... but the 2Q will fit in the 5Q mount with a 3D-printed adapter. Our vehicle doesn't have a side assistant yet, so we're installing the one directly on the 2Q system... I recommend removing the 5Q system and installing the 2Q system. NOTE: DIFFERENT WIRING! The 2Q System is much better. The Pictures from my Seat
Okay, but if I install the 2Q system, do I also need the mirror caps with the indicator for the blond spot? These are currently in my mirror glass. And is it true that not all facelift taillights have dynamic turn signals?
That's correct, the cheaper version of the taillights does not have a dynamic indicator function...no, you can continue to use the display in the mirror glass.
Thank you for your support! Do the lights without the dynamic turn signals have the same part numbers? But not the option?
