Im after a small badge that says Arosa to go on my front grill. I want to de badge it with the big S, and have Arosa in small on one of the side grills. Maybe it will look ok, maybe not.
Anyone know where i can get one? Or if anyone has one lieing around?
There aren't any available that attach to the front grill, you'll need to make one. I think I have the one I removed from the back of mine somewhere if you'd like it for the cost of postage.
You need 15 (i think) posts before you can PM people. Let me check I actually have the badge first (it's somewhere in the loft I think, but it's been a while)! And by the time I do that you may have enough, otherwise I'll get you my email addy.
The name and model badges will, but not the big 'S' one due to it being the handle!
A heat gun is easier as it will warm the glue faster, but be careful not to get the paint too hot. Try it with a powerful hairdryer first if you don't have a heat gun easily to hand - it may give out enough heat (i've done it with just hot water when i wasn't so worried about the paint underneath!)
Use dental floss in a sawing motion to cut the glue/sticky pad and clean up with a bit of tar remover
