Deleted member 103593
you can turn the radio off, rotate power button to 12'oclock and turn back on and will still be at original volume
Side note, does anyone else get annoyed at the power button spinning when changing volume, causing it to be the wrong way or wonky?
Ok, resetting the windows fixed the folding mirrors and the window closing feature!
The wing mirrors dipping when reversing has been fixed by resetting it and putting on the lhd setting. I'm a tad ocd with buttons and stuff so I always had it on the 0.
Hi devJord can you clarify how and what you reset to get the mirrors dipping when reversing. I've set mine to tilt in the car options and turned the mirror control to L but mine only tilt a few degrees so I still cant see the kerb. did you also have to adjust the passenger side mirror yourself so that you can then view the kerb and once you've done that do they then return to the normal driving position once you start driving again?
I've asked my dealer and even he is having trouble trying to get it to fully tilt.
Put it in reverse with it set to L, manually adjust the mirror while in reverse and then it'll remember that as your 'reverse position' leave it on L and drive forwards I think it's over 5mph and it resets back to normal driving position. Once you go into reverse again it'll go back to that manual position you chose before
Odd that the dealer doesn't know what to do though haha
cheers BenHarris3
I told the guy at the dealership that I thought that's how it should be done but he called me only this morning to say that he couldn't get it to work so id asked him to check with seat and get back to me.
It's not so much a mirror tilt function, more a "mirror do what the F you want while in reverse" function, so you have to set it yourself to wherever that may be
well of course you have to set it yourself - how the **** would it know how far forward you have the seat, how tall you are, etc? once you set it to the correct dipped position, it's automatic.
Nah that's definitely how it's done haha I have mine set to go wider and lower to get a full picture of the curb on the passenger side, resets again when I drive off, turn it to 0 or turn the ignition off
yup pretty logical and simple why couldn't they just write that in the manual and yes the dealer , well mine has been pretty clueless I've learnt more on here in a few days than they have in years
Sorry for the late reply, but I did exactly what BenHarris said. It worked like a charm.
The dealers are useless, it's not uncommon for me to know more than the dealer. When I bought my Ibiza FR Black Edition the guy was trying to tell me that the black edition has black inside the headlights instead of silver. I spent quite awhile correcting him on this and saying it's ALL FRs.
