Soopacoop Lcr rota grid drifts , ksport 8pots ,stripped and caged
Murdered LCR
Wide mouthed mofo
Sep 9, 2006
6,646
8
Murder Inc.
New orange key cover to match th harnesses , seat stitching and cage once its in ,
New solid compbrake top mounts
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
out of interest where did you get the top mounts from? Iv just replaced mine with OEM ones.
Murdered LCR
Wide mouthed mofo
Sep 9, 2006
6,646
8
Murder Inc.
They both fit my ap coilovers so yes they should ,
Fitted 10mm rear spacers and new Bolts had to cut the fronts down also had to dremel the centre of the fk spacers out as they wouldn't sit flush on the hub
Murdered LCR
Wide mouthed mofo
Sep 9, 2006
6,646
8
Murder Inc.
Got my cage in today Still loads to do have two doors bars to go in also a strait section across the back for the harness need the rear cross section welding and the mounts for the feet then I'm painting it in the car Was quite a pig to get in for those who want to know the cage is for a golf mk4 5 door
Trim the section out for the rear cage feet
Front section in what a absolute **** to get in had to jack the car in the air
Me cutting some of the door protection out to weld to
All in
Tight fit to the seats
