mattcymru
184
Hi Guys
What are the symptoms of failing spark plugs?
Are they easy to change also on a Leon 1.6s?
Many thanks.
Matt
Misfires, rough idle, jagged power delivery, poor fuel consumption.... it would be easier if you described the symptoms you're experiencing and let us try and advise what the problem might be.
ok the symptoms ive got is basicaly 8 times out of ten the car starts perfectly... on the odd occasion it wont turn over on the first attempt and on the second attempt ive got to give it some gas via the pedal to get it going.
Apologies for my non technical description!
it does always start just sometimes takes some persuasion lol, any other suggestions?
using a battery tester!
the collant sensor is the senor that measure the radiator coolant. Do a search
