Sports Suspension
Daz GTi
Hello all
I have recently put new 17" rims on my mk2 cupra sports and now I need to lower it :think:
I have read a couple of posts which say that the suspension cups rub. Can anyone recommend how many mm I would be able to lower the car without it rubbing and also which kit would be the best?
Daz
Mckellar
pretty sure 40mm is a safe bet with 215/45/17 tyres. not sure about the profile tho, might be 40 n not 45.
WeeC
238
Glasgow
40mm drop will be fine with 17"s. Sure the tyres i had were 215/45/17. Only scrubbed when full going over any dips or bumps sumtimes
alimac81
Victory is mine!
Nov 20, 2002
306
if you get it lowered, get a good set of springs and shocks (maybe with damper adjust), i got fk performance package and it was ok for a couple of months, then it settled in and got alot of body roll and rubbed like a git round the corners :think:
Mckellar
ditto on fk coilvers mate, rubs like a ****er now, rubs on any insignificant bump in the road, i am too lazy to raise my car though. :lol:
WeeJase
pert
Jun 2, 2001
8,595
left hand wheel arch liner might need a trim where the battery is located.
but from memeory 205/40/17 was the way to go with 17's.personally IMHO this looks out of place on a mk2,wide 16's look far more agressive with some spacers on the back to fill out the arches.car handles better too ;)
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
i had three sets of 16"s on my old 16v, tempted to go 17 but always decided against it, 16"ers look well spaced out and are by no means a compromise in either looks or performance.
Mckellar
alimac81 said:
Im running 205/45/16's on mine and the right hand wheel still rubs, even when im just moving at slow speeds :cry:
is there a reason for this, mines rubs mainly on the right hand side too, wondering if theres a reason for it, it only has rub marks on the right inner arch too :shrug:
alimac81
Victory is mine!
Nov 20, 2002
306
I think its the way the arch is formed to go around the air box, seems to be were its rubbing on mine :no: not much you can do, apart from removing them or getting fully adjustable suspension and thats expensive, not a good idea to remove them either, tried that and got a ton of dirt wedged up the wheel arch :doh:
Daz GTi
Cheers for the comments guys!
I've got 205/40/17s. I'm not sure whether to get Koni or FK - is the extra £100 worth it to get the Koni which are adjustable?
Daz GTi
Just from reading alimac81's comments was wondering if it would be worth it :think:
alimac81
Victory is mine!
Nov 20, 2002
306
I would probably go for the koni, at least you get some adjustment in case the soften up too much, (unless thats what u want)
