ok, so here goes,i want to convert the boc from double lamp to xenon.
bulbs in question
Double Headlamps: Bocanegra
Dipped beam - H7
Main Beam - H7
Sidelights - 2x W5W 501
Indicator - PY21W 581
Xenon Headlights
Dipped and Full Beam - D1S
Sidelights - W5W Blue Long Life 501 CANBUS
DRL (Daylight) - P21W 382 CANBUS
Indicators - PY21W 581
so,
lets say i just get the projectors lenses etc but no lights/balasts from seat and use all the original wiring from the boc, this is how i would wire them,
ebay HID kit- high and low beam DS1 bulb(that takes care of dipped and full)
(takes the feed from high beam and dipped )
Sidelights,(the boc has 2 sets as standard so we can re-purpose 1 of these)
DRLS- using the other sidelight wiring ill chop the connectors and run them to the DRLs,(both side and DRL will be on when the switch is in side position)
indicators are the same bar location, so that shouldn't be a problem.
this should see everything work properly with minimal fuss.
sorted?
or have i missed something?
Xenons
standard lights \/
bulbs in question
Dipped beam - H7
Main Beam - H7
Xenon Headlights
so,
sorted?
Xenons
standard lights \/
