CPearson
where is it located ?.
my esp light is on and i can only relate it to this as the MAF is new-ish.
thanks
chris
Hi mate,
I think it is somewhere on the steering column. I recently had a faulty one which was replaced under warranty. It was not working at all, but did not bring up the ESP light?
Hope this helps
Lee
dont know if its any help but fit one on a skoda fabia at work about a year ago and that fit in the rack at the side of the column slides in on a couple of bolts dont know if its the same idea
run the wheel full lock to full lock then road test it over 30kph should go out unless youve got a fault with the angle sensor itself.
its comined with the clockspring(airbag system) which is located directly at the back of the steering wheel
