RainyDay
92
7
Hi guys. Does anybody have an alignment results sheet for the new gen Ibiza FR 1.5? I got coilovers and it had the nice side effect of changing toe and camber settings in a favorable way. But I did an alignment and I believe I lost some camber and toe-out on the front. Just wanted the stock angles for reference to see if the current results are still "better" than stock. If anybody has them I would really appreciate it if you could share an image :)
Thank You.
So I'm not really enjoying the reduced toe out after getting an alignment. Car feels like it's understeering a bit more and less responsive.
Which direction should I adjust the tie rods on each side (CW or CCW) to toe each wheel out a bit more? Does anyone know how many turns to do on each side to add 1mm of toe out per side?
