strange rev increase please help!!!!!!!!
plymcupra
hi i have a 2001 cupra with revo stage 1 and have suddenly developed a problem with it.
The problem is when boosting hard up to 4k as you change gear the revs increase about 500 rpm. ive unpluged the maf but this didnt help.
the problem isnt so bad when usung the traction control but when its on it is much worse(not sure if less boost is used when its on)
any help would be brilliant thanks guys
super_stylin
212
ive had this a couple of times, when it happend to me the revs just seemed slow to drop and it was like they were holding, very strange. if anyone could cast any thoughts these 2 problems sound related
Beaker™
Slightly Unhinged........
Nov 21, 2005
1,900
C:\UK\Glos
Worth checking the switch on the arm of your clutch pedal. (search for 'clutch switch') It should look like this (the white switch), ignore the dimensions.
Dan Cupra R
The Yellow Sub
May 2, 2006
1,514
Reading
I agree with beaker, my clutch pedal switch is fooked and i get an increase in revs. Should be fine once ive changed the switch
plymcupra
thanks guys i will have a look at it later on today.
I dont have vag com but i am from plymouth are u alfy?
-alfy-
yes mate, cant find anyone down here with it. Think i might hvae to go about getting it, just wont know how to use it!
plymcupra
cheers guys all sorted now it was the pedal sensor!!!! alfy i will keep an eye out for you i drive a black cupra mate
plymcupra
cheers guys all sorted now it was the pedal sensor!!!! alfy i will keep an eye out for you i drive a black cupra mate give me a toot if you see me
plymcupra
if you pull out your fuse box cover at the bottom of the steering wheel on the left where the clutch pedal pivots you will see the white switch. if you unplug the wire you can screw it in and out for adjustment. if you get stuck i will take a picture for you mate
Beaker™
Nov 21, 2005
1,900
C:\UK\Glos
If its in place (its comman for the thread to strip and for the switch to pop out), then the switch itself needs replacing. If it has popped out then it just needs putting back.
super_stylin
212
yeah mine had popped out, i tried putting it back in but the thread was ****ed, popped some tape round it and wedged it in and it drives perfect now. going to get a new switch i think though,how much are these and thanks everyone for the help
