andrew_ww
130
Hello,
Of all a sudden I've noticed a quite bad water leak on the drivers side door. If it rains over night when I open the door there will be a significant amount of water on the door sill.
I don't whether this water is coming from within the door and thus is released when the door is opened or whether it is getting there by other means.
There is no sign of water on the inside of the door pillars or in the actual cabin.
Now were heading in to the winter I need to find out how this is happening.
Any suggestions as to what the cause might be would be appreciated.
Thanks.
Andy.
Probable the door seal, between the ancilliaries carrier and the door itself. This thread will give you a good start on all the leak issues that have been seen on this forum.
wet floor
please help.The floor in the back passenger side is very wet and also when i go round a corner i can see water leaking underneath the door in the front passenger side but the floor isn't wet. Does anyone know what the problem could be and how much it will COST to fix this problem. Thanks :cry:
