Stuck Actuator
Hutch
9
Hi guys,
I have a 1.9Tdi 90hp Ibiza which is going into limp home mode in 4th and especially 5th whilst under load (worse up hills). Stop and switch ignition on and off and everything is ok again.
I took it to a local VW independent specialist for diagnosis and they have advised that the actuator is seized, so I assume this is holding the wastegate closed and causing my issues. They advised that they can normally free them up but to do so would involve taking the turbo off and stripping it down....and they can't always guarantee success. Unfortunately I don't really have the money to pay them to do this, particularly if it might not be successful.
However I'm doing a lot of motorway miles at the moment and it's literally driving me insane, I'm quite handy with a spanner so I was wondering if anyone has any advice as to how to do this myself. Is there a way to fix this with everything still in place, or does the turbo need to come off and is there a guide available for this? And once it's off what's the best way to free it up?
Any comments or help would be greatly appreciated :)
Cheers,
James
sssstew
Editing your spelling
I think Seatmann means what engine code, to try and figure out if its a VNT or Wastegate model, but from my knowledge the 90 TDIs fitted to the ibiza's were all Wastegate models as they were older cars.
Alas, yes if your handy with a spanner then sure, drop the turbo off and give it a clean up, have a look at the following guide for doing it for a VNT turbo which you can adapt for yours (without VNT) :-
http://www.myturbodiesel.com/1000q/a4/VNT-turbo-removal-vanes.htm
Seatmann
Rough around the edges
Sep 16, 2010
5,575
10
Scotlanda
It's in the Mk3 section though stew so it could be the ALH or AGR, I know my old cordy of the same age and style came with either. Figured it would best to see which one it is first before I started posting links as the two use different fixing methods. The wastegate type can be sorted on the car.
But yeh I am asking for that reason, also OP do you have any fault codes?
