danwade333
12
Stoke
Hi,
seen loads of threads but can't find one to tell me exactly what i would need to fit a subwoofer to the ibiza 2013 without removing the head unit or replacing it i.e through rca adaptor?
any ideas?
if it is on here i can't seem to find it
cheers :D
You will need a rca adaptor spliced into the rear speaker outputs you'll need to wire the live wire to cigarette lighter or to a fuse which turns on with ignition and ground to cars metal and obviously power to battery.......are you using original head unit?
Yes its the original head unit. sub comes with a wiring set but do i need additional wires to attach the rca to the rear speakers? thanks for the help
Sorry for late reply your subwoofer should come with a rca wire with it...once you have spliced the rca adaptor into rear speaker outputs this basically gives you sub pre-outs so you subwoofer should just fit in no problems without the need for additional wires
