Suspension advice
Rich76
17
Hi,
I have a Mk1 Cupra 20VT and need some advice on upgrading the shock absorbers. The car was fitted with new standard Sachs shocks and Eibach Pro springs 5 years ago, the springs are 10mm shorter than standard Cupra, so same as Cupra R I think. The car has only done 25K since then, the springs are in good condition but the shocks are not great on damping - and not well thought of on here. I don't want to spend a on new shocks, I was thinking of Bilstein B4 or simlilar. Would these be a reasonable upgrade on the Sachs, or do I need to spend more? I am more concerned with roadholding and comfort than anything else, the roads here in Lancashire are in bad condition with lots of potholes.
Thai-wronghorse
Self proclaimed Cupra R addict & butcher!
Dec 3, 2015
2,199
1,038
Kent
Speaking from experience of using the Bilstein B4 shocks and Eibach Pro spring combination on numerous VAG cars over many years i can assure you that they're considerably better than the standard underdamped Sachs struts.
They're actually cheaper as well!
Sent from my SM-G986B using Tapatalk
