Suspension Discussion...
ReDBull
Every day's a school day.
Nov 21, 2006
2,990
14
Lincoln
I've fitted a nuespeed 28mm rear ARB at the weekend. Great kit very good quality fittings. Awsome did me a discount buy front and rear together. I'll get the front fitted when I have the turbo back exhaust fitted.
I'd recomend the Nuespeed.
Mr OCD
1,964
Manchester, UK
I just cannot make up my bloody mind !!
Anyone used the vogtland sports springs and shocks?... found them on Amazon for £224 and I've got some vouchers to use as well so could work out a cheap solution for me with cash left for ARB.
Mr OCD
1,964
Manchester, UK
Suspension kit has arrived from Germany :)
Other than replacing top mounts and bearings is there anything else should do at same time whilst it is all apart?
Sxanth
172
Colchester
Drop links tre ends ball joints wishbone bushes if your going the whole hog.
I wouldn't make it nose heavy with the ride height either it will make it unbalanced in heavy braking.
Mr OCD
1,964
Manchester, UK
I've gone for a 35mm all round kit... As standard they sit a bit nose high and hopefully the 10 mm lower front mounts will even it out without upsetting the balance.
