Well do do plan on doing that - putting OEM springs and dampers. Dampers are oem, just worn out I guess.
If anything changes, for better or worse, I'll then start to look for a solution for that problem as it arises.
Or it may be just fine.
I only test drove 4-5 Leons with 1.9TDI so I didn't notice at the time that the car I bought handles differently.
Can you recommend a good aftermarket setup for my 1.9TDI?
As I said, I don't need lowering as much as I need better steering/cornering and less roll.
