jones
14
Hi, I've been advised to change the tandem fuel pump gasket as have a very small amount of oil in the fuel filter.
I can see it's to the right of the engine and attached to the engine block with three bolts, is it as simple as draining the fuel as much as possible, remove and fit new gasket?
Thanks, Steve
Sent from my MotoG3 using Tapatalk
Yep easy job, just removed the fuel lines to drain, removed the pump, replaced gasket and reassembled then filled up the filter with fuel and the fuel system primed itself after 30sec of turning the engine over
