Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
Do you think you will be able to wind it that low without knocking the sump or wishbones / drive shafts on the chassis legs?
Sorry mate. Looks sick just don't think it's possible unless on air.
New purchase?
I will make the short two min drive to yours on the day of Pageant to see what's going on![]()
I've bought the Leon after having the bora so low that it rubbed all four arches away to nothing and then I just hated it!
Don't do it! It'll ruin your love for the car!
Before I had the H&R spacers on the rears and had zero fitment issues. The FK spacers also fitted properly, but with these you also bolt them to the hub so it has no room to move
They came very quickly mate, think about a week and they give you tracking numbers so you can be a impatient geek like me and watch it every step of the wayThese spacers come with the bolts to mount them to the hub but then you need bolts to secure the wheel to the spacers. The site says you can use your OEM bolts but I purchased a new set of bolts. The front ones needed trimming slightly though as they were touching the spacers. The website says you should be able to use your OEM spacers with no issues so thinking this happened to me as its aftermarket wheels
Get it lower dont listen to Tom he's gay wind them down If you need a hand let me know, some nice camber /caster top mounts will also work great mine come tomorrow
Stick with the height. It works and the handing is better for it. We lean towards the more 'race' group than 'scene' despite your wheel change in recent times![]()
You're still a hoonigan. Leave the height!
Nice one, thanks mate. I'm still hopeful I'll be able to use 10mm spacers and that I'll find some that fit my rear hubs but I'll bear the FKs in mind.
Bit confused what you mean - "The front ones needed trimming slightly though as they were touching the spacers" - can you clarify please?
Ah right, think I got that. Did the same ones fit on the rear OK though?
