• Hi Guest There will be essential maintenance on the server on Monday 10th November from 5am meaning the website will be offline for a period of time. We will do everything to ensure the downtime is kept to a minimum.
No need to run a 1 way on the line to the DV is the DV in the right way. It's goin to be a little different as its not got all the crap in the way.
aww right good! just thought i would check. defo made a difference tho boost feels stronger. all other guides on here are so confusing so cheers for a simple good guide!
I've done this before years ago but just used this to refresh my memory. Fool proof explanation, thanks for taking your time to do it. I've left you some rep
Can this be done in the same way for the cupra r lump BAM engine code ? Cheers
Thanks for this guide, looks very helpful compared to a few I have seen! I would love to get a bit more info & pics on fitting the resistors? Is it easy?
Also I plan to remove the SIA too, would you have a pic of where you blocked the actuator line?
Blocking the actuator line is easy of you have a ko3 just follow the pipe of the back of the Sai will go down to a nipple on the turbo. The other goes of the actuator to your n75 that's fine just block the other up to you how. Vac pipe with a bolt in it it don't matter. As for the SAI I'm doing one Monday can get some pics then. But simple and resistors I can get pics as well buddy.or look on my build thread think there is a pic of how I did it.
