this ever happened to you?
strapper
246
ayrshire
Just finished off the installation of my ths intercooler this afternoon, and I am very pleased with it might I say, then took the car out a test drive and it broke down. I suspect it to be two of the coil packs because when you run the engine you need to keep the revs up to stop it from stalling, and when you do that you can hear very clearly the missfiring from the engine. Fingers crossed thats what it is:cry:
Simon L
Audi TTS
Sep 24, 2004
1,253
Glasgow
Check none of the intercooler hoses have popped off.
This happened to me when the pipe from turbo to the SMIC popped off.
strapper
246
ayrshire
I had a feel at all the joins of the hoses and they appeared to be ok but I will need to double check tomorrow in daylight.
The car wouldn't even drive kept on stalling
Beaker™
Slightly Unhinged........
Nov 21, 2005
1,900
C:\UK\Glos
Check the hose between your charge pipe and your TIP. Does sound like a hose popped off. If it was a coilpack you'd get an engine management light come on.
t18con.
if its a popped off hose, itll still start with the maf unplugged.
