This will sound silly
Cupraporky
12
Dont wanna sound like a p**t here but wat do people's Cupra r bam boost at on stage 1 or 2 remap and what do people get from 3rd gear I've been and bought one with a receipt for a mapping at and and its holding 20 psi but in third gear I'm getting 120 out of 3rd gear were my friends is doing 100 in 3rd all on private runway off course
Sorry if I sound silly lol
Bigjohn84
Intagram / johnyoung84
May 5, 2015
2,330
Prob about right mate, I was on 19psi but now I've changed my spark plugs I'm getting 15psi, I'm on stage 1 LC tho.
irf
Feb 5, 2014
583
Think mines at 18-19 psi but I may be being a little silly here myself, are you saying you're third gear goes to 120 mph and your friends goes to 100 mph?
Cupraporky
12
Yer mate goes to 120 in 3rd his is just over 100 but wondered if this is cos its mapped
Bigjohn84
May 5, 2015
2,330
120mph is abit much in 3rd gear, I can get up to 90mph and I've still got a few thousand revs to climb, I dont do it tho.
Cupraporky
12
As unbelievable as it is its true I'm probably as shocked as u are but it has had recent gearbox in it I wonder if this has different ratios
irf
Feb 5, 2014
583
so what does it do in 6th? 290?:blink:
just joking but 120 sounds very high for the car, sounds like its either the wrong gearbox or could it possibly be reading in km/h?
fwiw mine goes to about 85 on the speedo.
Cupraporky
12
It's bugging me so much lol it don't feel that fast in 1 or 2nd soon as I'm in 3rd it flys lol it's on the rollers Saturday so we shall see
irf
Feb 5, 2014
583
the speed the car goes in each gear is to do with gear ratios, mapping doesnt affect that at all.
tbh you don't really want third to go as far as 120 (if that is whats happening) because itll be a lot slower then the same car with the same power but normal gear ratios. Think rally cars with "only" 300bhp but they just rip through the gears because all they want is acceleration between corners, the focus isnt on top speed. Even if you had gear ratios that could take the car to 200 mph you wouldnt have the power (or aerodynamics) to get to that speed.
andycupra
status subject to change
unless the rev limiter has been raised. or the other car isn't running correctly.
Cupraporky
12
At 90 I'm doing 5,000rpm I wonder if this is down to the mapping I need it looked at ASAP !!!
andycupra
ey? remapping could change the limiter, but it wont change the gear ratios...
3rd should be about 3,000 rpm at 40, meaning 6,500 at 90.
have you confirmed your speed is reading correctly?
but given its had a replacement gearbox? then is it incorrect. Diesel etc?
cupraslayer
I want more bhp
Feb 8, 2008
1,543
northampton
Sounds like the speeds you get from a civic type r . All Rev and go . Putting mine down santa pod there no way I would hit 120 in 3rd .
irf
Feb 5, 2014
583
You won't get those speeds even from a type r, driven a few ep3s and owned an atr. In fact the top speeds reached in gear are similar to our cars. Apart from cupraporkys obviously.
