Throttle body K1
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Need get replacemnt Tb for K1, im trying to find the part number for it, or revsion Q part number if any knows that..
May 25, 2008
1,919
S.Wales
www.seatcupra.net
Problem fixed
Went from:-
06F 133 062 G (30-12-05) Siemens (Came with the Leon TFSI Sport 06)
to
06F 133 062 J (03-03-10) Continental (Brought from eBay not too long ago, failed & will be returning back)
to the latest...
06F 133 062 Q (10-05-120 Continental (Brought from eBay again, but this time success working fine!)
Fitted the throttle body this morning and it has solved my EPC issue, seems like Q is the way to go...
Hope this helps!
Big_daddy
Oct 20, 2006
3,930
Brummy
so 06F 133 062 Q is ideal one to get ? isnt siemens better never herd of contienental?
Many Thanks
Big_daddy
Oct 20, 2006
3,930
Brummy
Thanks just making sure as want it back on the road,didnt last long when it got maped,
do all the 2.0 tfsi have same tb ?
May 25, 2008
1,919
S.Wales
www.seatcupra.net
About 3-4 Casual Hours?
Jacking the car up
Axle stands (High Point, so I don't break my back working at a funny angle!)
Bonnet up
Remove the Under Guard Tray
Remove the 4 Bolts holding the Radiator Fans
Drop the Fans down (Remember to unclip the Power connector)
Remove the Intercooler Pipe from Below
Then Undo the clip on the Throttle Body
Then remove the pipe connecting from Throttle Body to Intercooler
Use a small rachet with extentions to remove the 4 screws holding the Throttle body
I didn't bother replacing the Gasket (Optional)?
Once it's all done just repeat the steps backwards (Job done)
Note:- This is just a rough guide and how I removed the Throttle body
"do this at your own risk and this DIY is merely a guideline and I am not responsible for any damage that may occur when you do it."
Big_daddy
Oct 20, 2006
3,930
Brummy
Cool thanks... I figured it not going to be east.. just got custom Fmic and new under tray so going got whole weekend take it off... Compared to 1.8T 2mins job to change.. :)
