Throttle Fault codes... Ahh!!!
jaypee
174
Right, car is running really really lumpy, cant accelerate, sounds like a cylinder not firing (although i'm pritty sure its not that) ive tried changing the coil packs before I even got a chance to plug it in...
Ive plugged the car into VAG COM and got this:
17953 - Throttle Valve Controller: Malfunction
P1545 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low (because I have disconnected battery)
P1602 - 35-10 - - - Intermittent
17976 - Throttle Actuator (J338): Mechanical Failure
P1568 - 35-00 --
16486 - Mass Air Flow Sensor (FIXED: This isnt appearing any more, I changed the MAF)
PO102 - 35 -00 --- Intermitent
What is the Throttle Valve Controller / Actuator... where is it located?
Is it a sensor thats gone or has this unit completely failed.. as there are a few sensors around this... that I have no idea what they do...
Looks like I'm getting some oil coming thru from turbo too, so probably seals are going... would that cause the problem? I don't get any smoke out the back...
Thanks in advance!!!
jaypee
174
Throttle body?? Is this whats faulty?
Oil in inlet manifold...
jaypee
174
quick update, been reading thru some old posts, the actual bit that tilts in the throttle body seems jammed... opened up the back taken the cog out and still no movement, can i dismantle it further?
danielc16
cupra R dan
May 13, 2008
327
guildford
oil in manifold thats oki dont worrie about that and you cant tell if the tb is faulty as its all electrics inside it! try the big black connector block near the tb! take it apart and check the connections due to the fact i thought mine was broken but water got in the connections, if it is the tb i got a spare one
