Hi,
When I first start the car sometimes (not always cold) it seems to idle at about 1.25k - 1.5k and when I've been driving around it suddenly starts to do it as well, which is a pain when it's in gear and you're trying to slow down enough to turn a corner as it starts to pull!
I can get it to come back down again to under 1k when I physically pull the accelerator towards me with my foot.
Does anybody else experience this problem and what could it be - I'm assuming it's the pedal/cable sticking.
But any pointers would be good
EDIT: It seems to be when the revs drop below about 750 rpm, i.e. if you need to change down a gear. It adds some more throttle as if it's adding more choke, but it doesn't settle down again until I pull the accelerator up.
But any pointers would be good EDIT: It seems to be when the revs drop below about 750 rpm, i.e. if you need to change down a gear. It adds some more throttle as if it's adding more choke, but it doesn't settle down again until I pull the accelerator up.
have you had a look under the bonnet while a friend applys the accelorator?
