Timing belt & water pump change???
BASH29
244
East Midlands
I BOUGHT A lcr210 IN nOV 2009
IT DID NOT HAVE ANY HISTORY AS IT WAS ON A CAT D.
I CHECKED VIA VOSA AND MILEAGE IS CORRECT AND WARRANTED AT 70K
WAS WORRIED THAT ENGINE MIGHT BE ABUSED BUT WAS ASTONISHED WHEN I TOOK IT TO THE LOCAL GARAGE
THEY CLAIMED IT WAS ONE OF THE BEST STANDARD ENGINES THEY HAD SEEN
I THEN GOT IT DYNO'D AND IT CAME UP AT 216BHP STANDARD
IT NOW HAS 73K ON THE CLOCK AND MY MECHANIC SAYS THE TIMING BELT IS OK
SHOULD I CHANGE IT OR NOT, BASED ON NOT HAVING ANY HISTORY
ALSO IF I DO, SHOULD I CHANGE THE WATER PUMP AND STAT TOO
OR AM I JUST WASTING MONEY????
Jamie225
322
Leicester
yes change it if you have no history. better safe than sorry. water pump is a must as its a weak point on these engines. may aswel do stat with coolant out for how much it costs, i did anyway. £300 ish on cambelt service is better than ££££'s when it snaps imo.
skullmunki
Ding Ding Round 2!!!
Nov 12, 2006
502
get it changed, better safe than sorry......and the caps lock key is on the left of your keyboard above the shift key :p
Jun 26, 2008
1,299
Just round the corner.
I've got to get mine done on my 210. Bought it last week, lots of reciepts apart from cambelt.
I always have the belt/tensioners/pulleys, and waterpump changed every 4 years or 40k which ever comes 1st. On the waterpump, make sure that it replaced with the pump with metal impellors ar they are stronger than plastic type.
