Torque setting engine mount
19jeff89
67
Can anyone confirm these torque settings,
Is for timing side engine mount
Its for lcr
Sent from my SM-G930F using Tapatalk
19jeff89
67
There 2 bolts that bolt the engine mount to the engine mount bracket I've found two different settings one is 100nm the other is 60nm and 1/4 turn does anyone know which is right? It's for lcr
verbal_kint
639
31
North West Kent
From what I can see on oempc the bolts are common across all the Leons and into the Golf and Boraa and more.
My Golf Haynes manual states 100nm. But I think which setting you go for will not be that far away from the other.
19jeff89
67
Ok thanks for reply I've been trying to find out if ones for diesel and the other for petrol but no look yet. Yes they can't be far out I've heard of people's bolts shearing be for so wanted to be sure on the setting
19jeff89
67
I have just done a test on snap on torque wrench digital on a 17mm bolt and 60nm with 90 degree works out at 91.6 nm
