I have a toyosport cooler. Not sure which kit it is but I know the front has been mildly butchered to fit.
wellycooler???? never heard of them mate :banned: whos the best people to buy from
http://www.seatcupra.net/forums/showthread.php?t=288343&page=47
thats my one.
wellycooler is its nick name lol
toyosports sell them, its just the biggest one they do. you will need to buy the hoses separately and all links to the hoses are here
You will need 2 of these
http://www.ebay.co.uk/itm/Black-Sili...item27bbdda93d
2 of these
http://www.ebay.co.uk/itm/BLACK-SILI...item43a7d46976
2 of these
http://www.ebay.co.uk/itm/63mm-Diame...item1e64c383f2
8 of these
http://www.ebay.co.uk/itm/68-73mm-T-...item2a066aabdb
1 of these
http://www.ebay.co.uk/itm/Alloy-hose...item255f8be345
fitting was easy as its the 3rd one i have done on my lcr. i did have to do alot of cutting but its well worth it
Hii guys just fitted my welly cooler any one else noticed high oil temp after mines running aroun the 110 mark now when before was 95 is this ok ?
Funny this has come up, I have a fmic and was thinking it may affect oil temps so was looking around on a solution. An oil cooler is one but because the car tends to do a lot of short trips I'm not too keen as it'd take even longer to get up to temp with a cooler in the air flow.
Is there some kind of uprated oil/water heat exchanger available?
If you have proper oil you're safe yes. Remapped is more heat, simple. Normally my oil temp is between 100-110 degrees. When booting it I have seen 115 degrees. I would be worried for myself if it was above 120 for longer periods of time.
I'm no expert but I agree with ndphoto. As long as it's decent oil and you change it regularly (maybe even shorter oil change interval) you will most likely be fine.
