Triple beep when starting up
sfu
Hi,
Sometimes when I start up (MkIV 1.4SX) I get a triple beep and I have no idea what it is. It doesn't seem to be related to the amount of petrol or temperature. Seems to be quite random.
Does anyone have the same problem or know what it is.
EdButler
713
Sheffield
sfu said:
Hi,
Do any lights come on the Dash when it happens?
I found this - try doing a search for "3 Beeps" - but i cant say ive eard of it before:
http://www.seatcupra.net/forums/showthread.php?t=89317&highlight=beeps
sfu
Nope, all is normal with no warning lights.
The dealer didn't know and i'm hoping its just a dodgy sensor of some sort.
sfu
Chemical Al said:
low brake fluid? check the level and take the lid off then on again and see if it happens again.
I'll have a look this w/e, seems unlikey though as the beeping stopped for a few months and has recently reappeared (and now is quite frequent).
ta
sfu
toXXin said:
I thought 3 beeps was handbrake up while moving?
In my case the beeps are as I start the car, when the car is still parked.
gazjones
mine does this but i thiunk it is only when its warm which would be the high temperature of the engine coolant
Nath.
The Gentlemans Express
Jan 1, 2006
8,619
16
EASTLEIGH, HAMPSHIRE
I have 3 beeps on startup too
here are some things I know about it
if you get into the habit of putting the handbrake off before you switch on the ignition you may well see the handbrake light flash once in time with the first beep
also there is a small plastic button/nipple on top of the brake fluid reservoir just behind the filler cap, if you press it quite hard it fools the car into thinking the fluid is low and you get the same 3 beeps and one flash of the handbrake light (providing the handbrake is off)
so far I have found that if you start the engine immediately (don't stop the key half way) you don't seem to get the beeps
I hope this helps people
Jamo
Three beeps
Try starting the car without the stereo on... my Polo beeps three times if there is a traffic announcement stored in the memory.
Nath.
Jan 1, 2006
8,619
16
Dario said:
3 beeps:brake pads need replacement
as posted before my car does the 3 beep thing sometimes on startup and it has only done 6000 miles so I don't think the pads are that worn yet
BTW I'm still starting the engine immediately and not waiting for dash lights to go out and so far I have had no beeps
Nath.
Jan 1, 2006
8,619
16
Ric 2001 said:
Didn't think that the Ibiza came with brake pad sensors.
yeah I think they do come with brake pad level sensors (just a metal contact that touches the disk when the pad gets low and makes a circuit), but I don't know about it causing the 3 beeps :think:
gazjones
i have different head unit and it does it and i dont have the triffic on!
and mine has done it from virtually new so not the break pads!
Nath.
Jan 1, 2006
8,619
16
well a trustworthy guy told me that the fault is with the ABS ECU
you try getting the stealers to fit a new one, my local stealer won't hear of it although they have run out of ideas themselves
I think they are frightened of the price just in case it doesn't fix it
Silver Bullet
Large Member
May 9, 2006
77
do you put your seatbelt on before starting the car? that might be it also, are you sure you dont get any messages in the odometer when you start it? it's really easy to miss
Nath.
Jan 1, 2006
8,619
16
no I never put the seatbelt on before starting as I need to get out and shut the garage door
my beeps are intermittent tho?
messages in the odometer you mean like the service due thingy, NOPE
