Trouble getting my Fmic to fit. Help please!!
reflexuk
Future member
Jul 16, 2008
186
Nr Chesterfield Derbyshire
Can anyone help me with pics of a toyosports fmic fitted on a tdi pd130 please? I have a tdi kit
http://www.toyosports.co.uk/fmic-vw-golf-mk4-19-tdi-intercooler-kit-98-03--24499-1029-p.asp
and a couple of my pieces just have to be in the right place, but I'm strugling to pipe from the end of the u shaped piece on the fmic output to the long elbow with the map sensor in it which has a silicone elbow onto the EGR valve. I have the core running left to right, the opposite direction to a 1.8t. I will try to post pictures that will help explain
reflexuk
Future member
Jul 16, 2008
186
This pipe has the map sensor fitted to the left side, it's also the only bit long enough to reach back to the egr valve elbow. It cant turn down because of the alternator and belt etc so it must turn the direction shown. 99.9% sure this is correct
https://picasaweb.google.com/lh/photo/Fdw6pEzPNE47Yh6RNNxeBg?feat=directlink
I know I need a sfs hose end or egr delete to connect, ordered, hopefully in the mail.
reflexuk
Future member
Jul 16, 2008
186
This is what I'm left to do it with, 3 elbows! All different!
https://picasaweb.google.com/lh/photo/KAySSDncrPGthZ5ZYffTIg?feat=directlink
2 of them are the same either way round though 1 is longer than the other.
1 of them has a long side and a very short side.
To recap, I have a horizontal coming right to left at the bottom of the bay on the right of the pic in the previous post and a horizontal at the top of the bay going to the egr valve.
Any 2 elbows together will make an s bend but none of the combinations I have left are long enough to bridge the gap and anyways I have 3 elbows!
What's gone wrong?
reflexuk
Future member
Jul 16, 2008
186
Today I had another look at the pipework kit to establish what might be missing. I did this by continuing to fit the pieces that were clearly in the right places to see what the 'gap' they would leave looked like. This is where I've got to now.
https://picasaweb.google.com/lh/photo/KSUTdmwdn_isvxOv7dAejg?feat=directlink
I used the larger two elbows, longest first, then the smaller one from the bottom up. I'm left with the elbow with the one short side, I am missing a straight piece of alloy pipe of around 300mm in length.
reflexuk
Future member
Jul 16, 2008
186
An SFS hose end was delivered today. Here it is fitted with my existing seal.
https://picasaweb.google.com/lh/photo/eaCkfTzRZKsBNp0-hILZPQ?feat=directlink
The 90deg silicone elbow in the hose kit is a diameter reducing that looks like it's intended to go onto a egr delete pipe. As a result I cut 20mm off the end of it and dipped the end in boiling water to get it over the alloy bayonet connector.
Now the map sensor is fitted it can be fitted to the car. Here is what I am left with. Despite shortening the reducing elbow the alloy pipe doesnt quite run straight fore/aft and now points towards the goddamn dipstick!
https://picasaweb.google.com/lh/photo/SgTv5-BAAzF4dxJaUCuBhg?feat=directlink
reflexuk
Future member
Jul 16, 2008
186
Next I turned my attention back to the hot side. As I have swapped to a 1.8t pancake pipe which doesn't have the clip system. Like forum member Madman, I squashed the bumps on the small end of the pipe. Squeeze carefully with a mole grip, it's quite easy to do and a silicone joiner clamps on there quite nicely.
https://picasaweb.google.com/lh/photo/m9TPfPn3D0XeXvKejsx9mw?feat=directlink
The straight hose easily goes over the pancake inlet but, the same 54-62mm size clamp wont fit round it so I need to get a bigger one.
Red hose ready to fit.
https://picasaweb.google.com/lh/photo/Gl7OLcStdiWVEKseHPvoiw?feat=directlink
I used a bit more of the gasket sealant stuff because that's the last place you want a boost leak.
reflexuk
Future member
Jul 16, 2008
186
Tonight I am waiting delivery of a clamp onto the pancake pipe but I decided to finish fit the rest of the hotside pipework. I cut the corner of this bit of metal off so the pipe could butt up to the core.
https://picasaweb.google.com/lh/photo/MK4842Ry7GzQoUKaE4wNKA?feat=directlink#
I built it up with a dollop of the silicone sealant gasket to the joints for added security. It's hard to know when to stop tightening the clamps, I decided on a torque feel best described as 'quite tight but trying not to crush the pipe' lol. I keep reading about people having joints blow apart in use, also I don't have a boost leak tester so I'm trying to get it airtight first build. Fingers crossed.
reflexuk
Future member
Jul 16, 2008
186
Then I began the task of modifying the bumper to fit around the pipework. It's a case of cutting, refitting to see what's in the way cut and refit again, and again, and again until its done. I suspect I have it relatively easy here with a spacious LCR bumper. All the work takes place in the inner edges of the fog light apetures. I used a marker pen, a 4" grinder and a dremel tool. Here are the results, it looks like there will be room to refit the fog lamps. Yes, my bumper needs repainting.
https://picasaweb.google.com/lh/photo/kEKdx8q7Gc6-G-wnALT3pw?feat=directlink
https://picasaweb.google.com/lh/photo/lNkf2M_xbqjwxI8Itqln_Q?feat=directlink
https://picasaweb.google.com/lh/photo/R6bxCQwZ41QEBW6lWBCNEA?feat=directlink
reflexuk
Future member
Jul 16, 2008
186
HERE IT IS! Pipework conundrum solved.
The picture that everyone needs to fit this kit to their TDi :clap:
https://picasaweb.google.com/lh/photo/6V-05HPPLujOk34opRPCuQ?feat=directlink
If Toyosprts were just to put that one picture in their TDi kit then it would have been enough have saved me a 4 days of brain ache and lots of swearing.
I was looking around for the correct pipework route for days. Nobody could help me with advice but I found this vid on youtube which made me jump out of my seat. here's the key moment
https://picasaweb.google.com/lh/photo/jenYe6dx_LqpRu2hT_e_pg?feat=directlink
