As the title states,
Firstly I removed the bonnet felt because it was all mouldy, sagging and rubbing the MAF sensor. It sat on a table at work drying out for a few weeks before I decided to try and clean it. I bought some Dettol Mould and Mildew remover spray and set to work spraying the whole of the felt. I left it for about 15mins then rubbed it with a damp cloth and 'hey presto' all the mould was gone! I then left it to dry. I cleaned the underside of the bonnet, then sprayed the back of the bonnet and the back of the felt with 'High Temp Spray-Adhesive'. I then refitted the felt pressing it in to all the contours of the underside of the bonnet before putting in the clips. The result is the felt now "FITS" the underside far better. The real test will be when it is wet, will let you know how that goes!!
Has to be better than before though!!
