turbo 1.2 bar , coilpack problem or sparkplug or turbo???
black pearl
Newbie
Feb 10, 2006
55
2 months ago , I had a coilpack problem.. Second time in 6 months..
First time it was the first coilpack.
Last time it was the second coilpack. (i have used vagcom)
1 Month later i was driving on the free-way driving 120 km/h.
Turbo was boosting on that moment. I had 1.2 bar at that moment.
My engine make at that moment sound like a coilpack problem..
Engine (yellow controle light) started to blink..
I went of the pedal and the controle light stopped blinking
I stopped couldn't find anything at that moment..
At home i took the vagcom and it says misfire at the second cylinder.. :confused:
I was just a new one...
so i have reset it..
But now i stil have this problem...
When i boost from 0.9 - 1.3 bar it makes a sound like the coilpack is dead..
But if i boost from -0.4 - 0.8 bar nothing is wrong...
and the error code came one time back
Is this a spark plug or coilpack or the turbo???
karl.w
methanol junkie
Oct 26, 2005
606
sounds like a dead coilpack to me.
You could change the coilpack to another cylinder and if the fault comes back on the other cylinder then you will no it's the coilpack and not the plug
Beaker™
Slightly Unhinged........
Nov 21, 2005
1,900
C:\UK\Glos
Make sure the coilpack is pushed in tightly all the way. One of mine has been popping out lately, causing low boost and missfires under heavy acceleration. But drives fine on low boost and normal driving.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
do my trick pete.
remove your coil packs and cut a V into the rubber ribs on all the ribs down the side of the coilpack... so no air can be trapped beneath the coilpacks.
Its the std ribs which trap air beneath the coilpacks, and when the engine heats up, air expands and pushes the coilpacks out again.
mine used to do this occasionally... never done it since.
:thumbup:
Beaker™
Nov 21, 2005
1,900
C:\UK\Glos
do my trick pete.
:thumbup:
Good plan, will try that today, cheers mate :) My next step was going to be bolting them down but if i can get away with releasing the trapped air that would be great :)
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
it worked for me m8.
this is quite surreal, typing this on here when i can see your car out of my window! lol
Beaker™
Nov 21, 2005
1,900
C:\UK\Glos
lol, is quite odd :) If i could find the motivation to get off my a$$ you'd prob have seen me run out there with a knife and start hacking my coilpacks by now too. ;)
