Turbo code
Bigjohn84
Intagram / johnyoung84
May 5, 2015
2,330
You will have a K03, after 2004 was the K03s I think, I have the K03s in mine
Bigjohn84
May 5, 2015
2,330
He will have the AUQ engine so will the K03
AmD Stage 1 Map, Forge 007 DV, K&N Induction Kit, GT80 Milltek Sports Cat Back, 40mm Springs All Round
dazjstuart
660
8
Aberdeen
There is no such thing as a K03s. There are a range of K03 turbos the later ones for 180bhp motors have a different compressor wheel and housing aswell as a stronger actuator, it is referred to as a "K03s" by the "scene". As far as I know all LC's with the AUQ engine have this model of turbo which is model no 5303-988-0052. You may see it referred to as a K03-052.
Bigjohn84
May 5, 2015
2,330
Your saying theres no such thing as the K03s but saying the parts are different from the earlier K03. That's like saying there no such thing as an R2 motorbike even tho the R1 has completely diffrent parts on it. I messaged a turbo dealer few days back and mentioned the K03/K03s and they new what it ment. The K03s has a smaller compressor and spools up sh.it loads faster than the K03. Two same turbos with diffrent parts.
AmD Stage 1 Map, Forge 007 DV, CDA Induction Kit, GT80 Milltek Sports Cat Back, 40mm Springs All Round
Bigjohn84
May 5, 2015
2,330
Also all modles of the LC Auq dont have it. Under 2004 had the K03, over 2004 had the K03s
dazjstuart
660
8
Aberdeen
I direct you to this thread http://www.audi-sport.net/xf/threads/the-facts-about-the-k03-turbo.5970/ where Borg Warner confirmed to the chap there is no such thing as a K03s. I also had this discussion with a supplier when I replaced mine, as you said they knew fine well what I meant by a K03s but for the purposes of part numbers (which is what the OP wanted) it's unhelpful because none of the part numbers contain K03s. Just because everyone calls it something else, doesn't mean its true. Take the fabled Subaru "EJ20T" engine, that doesn't officially exist either, you get an EJ20 and you get a turbocharged EJ20 but it has never been officially called an EJ20T even though that's what everyone knows it as.
I'm 99% sure all AUQs do have the "K03s", mine is an 03 and has one as did my friends 52 plate one and I haven't heard of one on here having anything but. There may be some older LCs with a non AUQ engine that have the older style turbo. The older model K03 turbo tends to be on Golf GTIs. The new ones came in long before 2004.
Bigjohn84
May 5, 2015
2,330
There must be two part numbers then for the old K03 and the newer K03
seatturbopower
350
birmingham
AUQ engine with the K03S turbo 2003 plate,wanted more power out of a good shell so I brought a hybrid K03S even better :)
by the way liam if you need a K03S let me know I have one spare.....I done about 5k on it I think but I have the receipt to show with it also dated in jan 2014,it was on the car for 1 and half yrs.nothing wrong with it just changed turbo as I said.
Bigjohn84
May 5, 2015
2,330
Are you sure there's something even called a hybrid K03s lol think someone will say there's no such thing haha
kiemcd
46
There's a couple of hybrids based on the ko3s turbo isn't there ? Do BBT not do one ? The path I was thinking of going rather than ko4
