turbo cutting out since remap
chriswilks
Astra CDTi track car
Jun 3, 2007
330
warrington cheshire
recently had my leon 180 remapped by response chips since then turbo cuts out at 5000 rpm then keeps coming in and out.anyone had this problem?had new o2 sensor and throttle b cleaned.any ideas??
chriswilks
Jun 3, 2007
330
warrington cheshire
its fine in 1st and 2nd then does it throgh to 6.someone suggested maybe the fuel pump cant cope???also theres no turbo when i start it first time?!its really odd!!
chriswilks
Jun 3, 2007
330
warrington cheshire
they say it should be 230-240 bhp although it feels no quicker than std which im guessing it should.they said if im not happy id be refunded!u recommend anywhere else to get it done?
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
search the following on this forum.
jabbasport, revo, custom code, ptorque .
they are all well used on this site.
if youve no other mods you should hopefully see 220bhp. some offer custom tuning which might get you another 10bhp.
unless your fitting a sports cat i wouldnt bother getting a custom map.
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
you really want a boost gauge to see whats happening
however i'd go back first thing cos it doesnt sound good
but 230bhp from just a remap...no chance in hell, prob more like 190-200
chriswilks
Jun 3, 2007
330
warrington cheshire
im taking it back 2moro!!!just been driving it!if they cant sort it at least ill get £££ back for new exhaust!!
this has put me off doing anything further to my car now!!is it really worth spending so much money to get what appears to be so little....will i notice a filter and exhaust and remap?????????help b4 i set fire to it!!!!!!!!!!!!!
olaf
Dodo Lover!!
Aug 19, 2006
1,081
29
Ipswich
It more highlights the need to go down a tried and tested route!
Had you heard much feedback on their previous work?
Mitchy
TTRS
Oct 12, 2004
2,310
If your not 'overwhelmed' by the result of a remap, you have an under reading maf.
If you have surging boost you have a faulty N75 valve.
Sounds like you have both faults to me.
Easy as, and a decent tuner should have been able to diagnose this. He should have been logging your vagcom maf values to diagnose this dodgy MAF sensor.
Ive never heard of response chips, not to say they aren't any good but you should have done a bit of research before choosing which map to go with.
Buy cheap, buy twice springs to mind;)
Simple search on here would have brought up Jabba/Revo/CC/APR/P-Torque etc
All the best with it bud, dont give up. Change these 2 and it will be as it should:)
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
Sounds to me also like the map needs something like an n75j valve, lesser known map have used n75js in the past my old one included, it fluctuated like hell until it was changed.
Mitchy
TTRS
Oct 12, 2004
2,310
Yep could possibly be the DV also, especially if you haven't uprated it. standard valves are a weak point.
You would probably hear a leak though or a chattering noise if DV wasn't doing its job.
chriswilks
Jun 3, 2007
330
warrington cheshire
right......just got back from having car looked at!theyve suggested poss faulty maf sensor they are aware its a common problem, they also said its most likely to be the std exhaust if its fine in 1st and 2nd it shoulndt be the maf.
theyve offered my a blueflame exhaust with high flow cat and rolling road for £300 to get everything right.should i take them up on this???what would u do?
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
they've not got a clue....
did they log the car/maf values to tell you this?
exhaust should be fine unless it's fallen to bits
