alexsteele
hi guys a little bit of help needed.... my k04'd ibiza cupra has developed an oil leak from one of the oil lines... i believe to be the return (bolts onto the bottom of the turbo with 2 M6 bolts and runs straight to the sump. It appears to be leaking around the join from metal to braided pipe... are the oil lines for k03 and k04 different as i bought the car with the bigger turbo fitted so do not know myself... thanks guys.
The k04 oil pipe will fit without modification to the mount it's just a tight fit but from vw I payed around £65 it's about a 15 min job hope this helps
