Turbo - Options
aaron99099
so i set off today in first and put my foot down, big clunk and a LOT of blue/white smoke, turned into a car park and switched off straight away
got a leon 2.0tdi 140 remapped and when he mapped it he said it gave an error like the turbo was on the way out, plus its sounded like a police car for a while whistling away, wont be in garage until monday but im assuming the worst
let me know what you guys think, what my options are regarding new/recon/hybrid turbos and roughly how badly i can expect my bank balance to be affected, and also where to look/companies as i have no idea
andyspencer
Eat My Soot
May 19, 2008
263
Birmingham
Defo turbo gone. PD140s are prone to it, more so if the map was agressive.
New replacement garrett should cost £600-£700 ish. Recon will be less. New hybrid stage 1 will cost you about a £1k. A bit less if you can get them a turbo to hybridize (lol) but yeah, then your looking at fitting, and possible cleaning of your cylinder block and intercooler if its dumped oil everywhere. not pretty.
i recon at best £900 at worst £1.5k all in
aaron99099
Any idea what parts i need to order? Obviously a turbo, but ive read on here ill need a new oil feed pipe from seat and new engine oil and filter because t has to be drained?
greyfloppyhat
Senior Member
Jun 14, 2011
673
Dublin/Belfast
dont get the oil feed pipe from seat, just get a braided one from a motorfactors, cheaper and better. New exhaust gaskets. If the IC is going to be drained I would look at getting new o rings for the boost pipes flowing into it also.
Have you tried looking at just buying a new core? Or getting the old one recon'd rather than buying a recon. It may work out less as there mightn't be much wrong with the turbo.
aaron99099
Would ebay item 130668186972 do the job?
Do i have to get the gaskets and seals from seat dealers?
It went with quite a lot of noise/smoke so im presuming its pretty bad but it wont be in the garage until after my holiday so wont know until we remove it, found a recon for £290 delivered if i send them my old one
just trying to get the parts together so i can take it to my mates garage on a saturday morning for mates rates rather than paying full whack through the garage
greyfloppyhat
Senior Member
Jun 14, 2011
673
Dublin/Belfast
That would be perfect, Darkside are legends when it comes to tdi products. £290 isn't bad, assuming it has a decent warranty and is a good refurb.
