turbo wear and hybrid
freedom875cc
does anyone here know what the play limits in the turbo shaft from a pd150?
pulled mine of and its got around 0.38mm of play.
Also how much have people payed for exhcange standard or hybrid turbos?
cheers chaps and chapets
dom
Feb 1, 2007
1,602
Nottingham
That sounds fine to me.
Regarding costs there is a huge difference in cost variations depending on who supplies it.
Turbo Technics tend to be very good on price.
Standard rebuilt turbo for a pd 150 around £380 exchange or £550 hybrid, which is what I have.
Glynn
freedom875cc
0.38 radial or longitudal play?
Sorry, radial. Spoken to TURBO TECHNICS and they say "upto 1mm radial, but no play longitudal"
And it also turns out i have longitudal play too!
So they are offering to rebuild it for £245 +VAT which doesn't seem too bad to me.
cheers for the reply guys.
dom
majesty78
490
Austria
Watch out to get genuine garrett spare parts and a plot from balancing when you let your turbo rebuilt!
Greets, Alex
Ibiza 130 tdi
Black Magic
Jan 15, 2007
6,275
Somerset
Turbo Dynamics charged me £600 to hybrid a second hand turbo, although they did do a brilliant job with it! Brought it up like new!
Ibiza 130 tdi
Black Magic
Jan 15, 2007
6,275
Somerset
AmD 230bhp and 330ft lb
no slippage on the standard clutch... yet... :whistle::ill:
That's low torque for a hybrid! seems all the turbo technics turbos are down on torque in comparison to the Turbo Dynamics.....
I'd never consider running hybrid on standard clutch! You have nuts.
volvic
It's just water
Jun 28, 2008
791
House of Batiatus
down on torque? what "should" i be getting then? glynnd managed 350ft lbs from turbo technics.
not sure if AmD took into consideration that i did not want to change the clutch
either way im a happy lad! im not booting it under 2.5 revs and im using the gears for longer. the power is right through to the redline
Ibiza 130 tdi
Black Magic
Jan 15, 2007
6,275
Somerset
I'm not bad mouthing the work you've had done fella, but as a rule hybrid diesels seem to get around 360ft/lb ish. I only know of 3 though.....one is 370ft/lb and the other was 372ft/lb I believe. Tall-Paul had his done too but I'm unsure of his figures.
volvic
It's just water
Jun 28, 2008
791
House of Batiatus
none taken mate, just didn't actually know what others ran after a remap.
