hi, all I need to get the valve sensor things for y wheels and I don't know what ones I will need as I have new wheels to go on but they have normal valves.
The Mk2 Leon doesn't use them. It uses a passive monitoring system through the ABS system that looks for small differences in wheel rotation speed across each axle.
Did your old wheels have sensors or did you presume there were ....if later then as previous quote...if had sensors you need one from old wheel to get part no ....as i have a feeling the facelift mk2 had the option...may be wrong so don,t quote...
