Tyre size
briscoe
73
Had a quick scout on here using search but haven't found what I was looking for. Does anyone know if 225/45/17 would fit without rubbing or anything?
Regs,
Nick
briscoe
73
What car are you fitting them on
Sent from my H8216 using Tapatalk
Weird I had another sentence with car details on but it's not posted it. The car is 2006 ibiza fr tdi with the factory upgrade 17". I'm currently running 205/40/17
RUM4MO
7,823
1,000
South Scotland
Dismissing the rubbing possibility, the rolling radius of these tyres will be a lot more than the standard fit tyres, so will annoy your insurer as they are not a homologated/approved size, and the speedo calibration will be out.
SEAT Rule
188
62
Bit more information for you if required.
SEAT Ibiza 1.9 (year 2006 to 2008)
Tyre size 195/50R15
Wheel rim width 6j X 15 ET43
Wheel center bore diameter 57.1mm
Wheel bolt fixing 5X100
Wheel bolt thread M14 X 1.5mm
Tyre size 195/50R16
Wheel rim width 6.5j X 16 ET43
Tyre size 205/45R16
Tyre size 205/40R17
Wheel rim width 7j X 17 ET43
SEAT Ibiza 1.4 / 1.6 / 1.9 / 2.0 TDI
(year 2008 to 2015/16)
Tyre size 215/45R16
Wheel rim width 7j X 16 ET43
Tyre size 215/40R17
SEAT Ibiza 1.6 TDI
(year 2017 to 2020/21)
Tyre size 195/55R17
Wheel rim width 6.5j X 17 ET47
Tyre size 215/45R17
Wheel rim width 7j X 17 ET51
Tyre size 215/40R18
Wheel rim width 7j X 18 ET51
I don't think the size 225/45R17 was an option for the Ibiza, I could be wrong but can't see it anywhere, a part from listed for the SEAT Leon TDI FR and Cupra models.
I'd imagine they'll rub if fitted to the Ibiza possibly too wide ??
Also the wheel bolt hole circumference on the Ibiza is 5X100 but on the Leon it's 5X112 so probably won't fit anyway.
SEAT Leon TDI (year 2006 to 2008)
Tyre size 205/55R16
Wheel rim width 6.5j X 16 ET50
Wheel bolt fixing 5X112
Tyre size 225/45R17
Wheel rim width 7j X 17 ET54
Tyre size 225/40R18
Wheel rim width 7.5j X 18 ET51 also ET53
Tyre size 225/35R19
Wheel rim width 7.5j X 19 ET51
Hope this helps
Si
