ecosse1986
78
Fife, Scotland
Hi folks
i own a mk4 ibiza the tyres that are on my car just now are 205/45/16
i need new tyres and i have been offered 4 tyres
3 are brigdestone and 1 is continental and the size is 205/50/16
will these be ok? if the side walls are 5ml bigger? from the tyres that are on my car just now?
Ian
They won't be 5mm bigger - they'll be 5% of 205mm bigger.
The second number refers to the side wall height in ratio to the tyre width.
In your case the sidewalls will be 10.25mm taller - that's quite a big jump.
Hi folks
Ian
as stated
The sidewall is NOT 5mm bigger - it is 5% bigger.
5% of 205 is 10.25mm
Yes they should fit
Due to the higher profile the car will be going 3.4% faster for the same speedo reading.
