Unable to reset/retrain window
bartekp19962
8
Hi All
I have seen multiple threads on procedure how to reset/retrain windows however it does not work for me - any thoughts?
Leonfrdiesel184
154
37
Hi mate mine did this and when I connected my obd connector and did a scan there was a fault code to do with the windows. I cleared this code and was able to set the windows up again. Code never came back at all think it was due to the cold weather at the time. I use carista and the free car scanner app to do this. It's brilliant mate highly recommended
Reactions: bartekp19962
bartekp19962
8
Right okay - will have to Invest in OBD
Reactions: Leonfrdiesel184
cairus
1,673
588
The error log with the error "basic setting missing" is completely irrelevant for programming the window. I recently had 10 errors in the door control unit and was able to program it.
How do you learn the window?
Leonfrdiesel184
154
37
Hi mate was only saying it worked for me. I have reprogrammed the window many times but on this occasion it wouldn't do it until I cleared the fault and I was instantly able to re learn the window mate
bartekp19962
8
I have used various suggestions from various threads and also referred to user manual
bartekp19962
8
Hi All
Update on this - OBD arrived today after plugging in i am unable to clear this error guessing will need new window regulator? Any suggestions to try before replacing the part?
