***urgent**** i need help
lamby
54
Hull
Hi
I really need some help Ive tried to change my track rods and bottom ball joints today and had one nightmare after another NOTHING has gone right , the car is on axle stands right now.
I need to get the car done this weekend.
So can anyone help me, there will will beers a plenty for anyone who can help.
Many thanks
lamby
54
Hull
Both ball joint nuts are seized solid same with one of the track rod ends
Sent from my Desire HD using Tapatalk 2
cupra-barn
It's all about stealth!
Aug 4, 2010
2,109
Worcester
Is it the ball joint but on the top or the 3 on the bottom?
On the track rod end, IMO you just need some freeze release or give it a good soaking of WD40 or the like
lamby
54
Hull
Thanks bickerton they look like it will do the job. I'll just have a to try and cut one of the small ones off the ball joint. Sorry it took so long to reply I've had a bit of bother with my internet
lamby
54
Hull
Both ball joints done but I've sheared a bolt for the sway bar just one track rod and I'm done
lamby
54
Hull
All done thanks guys just need the tracking doing (its f**king miles out it looks like its trying to pull the tires off!!!) found one of the ball joints was only held by 2 bolts.
