littlebigdunc
Hi guys car been running bit laggy recently like its holding back, the other week a coil poped and had to replace it but since then its not been right, i was on holiday when the coil went so had no vagcom with me had to get a local garage to clear code my car.
Now after returning from holiday the car still dosnt feel right so i scaned it tonight with my vagcom and got these codes im not 100% sure what they mean can anyone help?
Address 01: Engine Labels: 06A-906-032-AJQ.LBL
Controller: 06A 906 032 DE
Component: 1.8L R4/5VT 0001
Coding: 11510
Shop #: WSC 06441
2 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 -- 35-10 - - - Intermittent
16805 - Warm Up Catalyst; Bank 1: Efficiency Below Threshold
P0421 -- 35-00 - -
Readiness: 0000 0000
is this lambda related??
From the Ross-TechWiki
18010/P1602/005634
Possible Causes
Cables on the Battery were removed
Battery weak (voltage)
Generator Disfunction
Possible Solutions
Check Battery Cables
Check/Replace Battery
Check/Replace Generator
Special Notes
If multiple Control Module have Power Supply Faults stored, it's most likely to be one common Problem like the ones shown above. Otherwise when only one or two Control Modules have such Codes stored you better start searching at the individual Power Supply of these Modules.
Terminal 30 means unswitched battery power that is supplied even when the ignition is off. This is not referring to any physical terminal numbered 30.​
So, check the battery and the alternator.
16805/P0421/001057
Possible Causes
Warm Up Catalyst Bank 1 faulty
Possible Solutions
Check Warm Up Catalyst Bank 1
Set Readiness
Replace Warm Up Catalyst Bank 1
The description here is not helpful. From what I've been able to find, the usual first step is to replace the pre-cat lambda probe.
i was thinking lamdba, i have also had the battery disconected recently so i think that may be the issue of the 1st code
