Lewis225
Barney Mad
May 30, 2008
114
Frome
Hi,
I brought a pikey cable (blue) from e-bay as my car has starting issues when warm, it came with a software disc with loads of differant files, I don't know which I'm supposed to download. Anyway I downloaded something, went into the options menu, tested port and all seemed o.k. The first time I hit autoscan a list of faults came up but then it stopped working, now when I try to scan again it just says "vag.com has stopped working" and takes ages for me to close the window. If anyone has any ideas Please help as I'm getting nowhere and starting to hate the cat I loved.
Regards
Tim
H, it says VAG.COM release 409-1??? my computer also says VCDS lite but nothing happens when I select it, the guide did say something about vista but I really don't unnderstand what it's trying to tell me.
Thanks for the quick reply
I'd be wary of the software provided by anyone other than rosstech - too great a chance for virus & trojans
Oh dear, I have looked at the guide on your vista sticky and the port is def working as I get the same message as in the screen dump reading "port status ok, interface found, type serial pass through, opto/iso no, Ross Tech design no????
Maybe I should try to relaoad the lite from thee disk???
iT WORKED
Wow, went ot to the car and the lite version loaded up, gave me loads of codes with please register/activate, but it also told me
16804-catalyst system:bank 1:efficiancy below threshold=Milltek sports cat
17949-fuel pump relay (j17):eek:pen circuit-p1541-35-10-intermittent
17635-fuel injector for cylinder 3 (n32):short to ground-p1227-35-10---intermittent
17833-EVAP purge valve (n80)-short to ground-p1425-35-10---intermittent
01276-ABS hydraulic pump (v64)-012-electrical fault in circuit-intermittent
Any help with what the problems could be would be great.
Regards
Tim
