sonic, you need to supply the engine ident code so that Uwe can advise you. It will be stamped on the engine, next to the gearbox join, and also on a label on the cambelt cover; also it is on the build sheet in the boot, under the carpet, which might look something like this -
VSS ZZZ 1M Z 1R012345 - - - Chassis number 1R012345
1M15 36 - - - - - 1M1=Leon
LEON 1.8 T SPORT
132 ABC D6E - - - - - 132 KW = engine power
AUQ FZQ - - - - - Engine code AUQ and Transmission code FZQ
That having been said, I can't find a 1.8T in a Leon I that has EGR. Doesn't mean that there isn't one, though, just that I can't find it.
Uwe, maybe you can give an opinion here, as I am confused by the use of EGR on a petrol engine. Diesels have no means of reducing oxygen in the combustion charge other than inert gas injection, but petrol engines have a throttle. Is it really just to reduce pumping losses while achieving an approximation to lean burn? That could explain why it seems to be confined mainly to lower-powered engines.
