vag com softwear
Theresias
But of course there will be things which will never work...
Common difference between versions and between Fully Registered and Shareware.
Shareware:
Cannot do AutoScan
Won't display text for all fault codes
No Basic Settings (so no TBA, Xenon levelling, etc or checking timing on TDI's)
No Adaptation Saving (so no changing of locking/lights/horn behavior)
No Output Tests
No tech support from Ross-Tech
Limitations of 311 and 409 even if Fully Registered:
No Generic OBD-II
Won't work with CAN-Bus vehicles
Fewer fault code definitions and label files
No built-in Activation (you'll be limited to a single PC)
No Advanced Measuring Blocks
No Acceleration Measurement
...unless you settle for the real deal to begin with. If you plan on working on the new Ibiza (6J/MK5) or other models you should get the HEX+CAN right away.
