Justin R
92
I've been speaking to LEE69 who has been helping me with my VAG COM software.
I have intalled the VCDS software and now correctly installed the driver software (so i think i have as i can now test the lead. I used this: -
http://www.ross-tech.com/vag-com/usb/usb-config-vista.html
Unfortunately im getting the following on the test, connector not plugged into the car: -
Status: Questionable
K1: SHORT TO GROUND
K2: SHORT TO GROUND
CAN: Questionable
The link says i should be getting OK's.
Anyone any ideas? I had a quick look inside the lead and nothing seems wrong, no damaged or broken leads, wires etc??
I plugged it into the car and carried out the test and everything seemed ok. I couldnt see it ask to plug the lead in to the car to carry out the test!?
I've been having a quick look around it. i did get the following fault codes: -
Address 01: Engine Labels: None
Part No: 1ML 906 032
Component: 1.8l R4/5VT 0001
Coding: 10510
Shop #: WSC 00000
VCID: FEF96021FAECD49
VSSZZZ1MZ3R135115 SEZ7Z0C2023379
2 Faults Found:
16486 - Mass Air Flow Sensor (G70)
P0102 - 35-10 - Signal too Low - Intermittent
17608 - Boost Pressure Control Valve (N249)
P1200 - 35-10 - Mechanical Malfunction - Intermittent
Readiness: 0000 0000
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 F
Component: A7 Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 06403
VCID: 3A712C312644B89
Subsystem 1 - Part No: 1C0959802B
Component: A7 Tõrsteuer.FS KLO 0009
Subsystem 2 - Part No: 1C0959801C
Component: A7 Tõrsteuer.BF KLO 0009
Subsystem 3 - Part No: 1C0959811A
Component: A7 Tõrsteuer.HL KLO 0009
Subsystem 4 - Part No: 1C0959812A
Component: A7 Tõrsteuer.HR KLO 0009
3 Faults Found:
00849 - S-contact at Ignition/Starter Switch (D)
25-10 - Unknown Switch Condition - Intermittent
01134 - Alarm Horn (H12)
49-00 - No Communications
00930 - Locking Module for Central Locking; Rear Left (F222)
27-00 - Implausible Signal
I reset the DTC's, drove it to work this morning and got: -
17987 - throttle Actuator (J338)
P1579-35-10 - Adaption Not Started - Intermittent
Readiness: 0110 0101
I dont know if i caused this when trying to adjust/rest the throttle body with it on to start with.
I did also look at the MAF fault code on google and posts on other forums were saying signal too low normally points to damaged wiring or pins in connector rather than MAF. They said signal too high would indicate MAF issues.
What are peoples views on this?
