Vagcom in coventry (west midlands)
goldie87
319
Midlands
hi guys, is there anyone that could check my mk1 leon?
having problems with starting my car and also the rev meter going crazy (up and down, revving itself, etc)
goldie87
319
Midlands
cheers guys, im from stoke in coventry. i had the throttle body cleaned because i thought it might be that, but it didnt do the trick, i was thinkin maybe it needs replacing?
goldie87
319
Midlands
just got the car checked out an apparantly its the lambda sensor and temp sensor that needs replacing, can anyone do this? or could recommend someone? how much should i be looking at?
Feb 26, 2009
5,275
Wolverhampton
Temp sensor £30 and an hour to fit (with a coolant flush probably), lambda sensor £50-£100 each (there are usually two so find out which one you need to replace) and an hour to fit.
