Ant FR
2,861
Kent
Ok, my mates tdi has developed a strange one, will not start intialy, takes about 15 secs on starter then eventiually fires up. but once running it so loud under the bonnett, does not boost, and loads of black smoke if revvd. it also hunts on idle.
plugged in vagcom and under engine block got
17656 - Injection Start Regulation: Control Deviation
P1248 - 35-10 - - - Intermittent
any ideas exactly what this is and where do we start to try and fix it.
oh its a 110 tdi engine, has about 140,000. this problm appeared overnight without warning, next morning it just would not start.
help
On the 110tdi there is no in tank pump, if it takes that long to start then the first place to look at is to see if the there are any air leaks in the fuel pipes the fuel could be draining back to the tank.
Put a new fuel fillter on and make sure all pipes are seated correctly.
