VAGCom
Joe_3490
404
Big MPH
Teardrop wipe
Dial staging
Alarm bleep
Single press central unlocking
all done - at last :)
Nice, I have got the Carista OBD adapter coming today so over weekend I hope to be able to do some mods.
what other options were available for you when you went through the carista app?
camelspyyder
2 SEAT-er
Jun 26, 2014
1,307
176
Go to Carsita website - the Vehicles tab lists all the cars and what you can do.
I haven't tried the newest beta yet.
Lucky 2016 model owners can do all of this without any add-ons - the new SEAT Media System Plus has a menu for "Car Settings" which does the same stuff.
Joe_3490
404
Lucky 2016 model owners can do all of this without any add-ons - the new media system has a menu for "Car Settings" which does the same stuff.
The Toledo doesn't have a list, that is why I asked :)
also I got some free play credit so I purchased Torque Pro app to play with aswell
Joe_3490
404
I thought so, wasn't sure if we had same features, Unsure if the windows from remove would work as we do not have one touch in the Toledo, but I guess it may do,
but the large MPH and unlock single click are the two I want most :), Plus i have the Beta version so see what that may include :)
camelspyyder
2 SEAT-er
Jun 26, 2014
1,307
176
The all windows feature doesn't work - the hardware isn't in the car.
large MPH is very nice, but single click locks - Halleluja, all that frustration - Gone!
camelspyyder
2 SEAT-er
Jun 26, 2014
1,307
176
Haven't tried much on the Ibiza - SWMBO will kick off if I mess about with her car without her say-so - but I have added digital MPH to the above the line display options, which also binned the KPH display below the line.
Joe_3490
404
Haha I know the feeling,
My adapter has been delivered, :D
How did you add MPH? was it changing location to Aus?
camelspyyder
2 SEAT-er
Jun 26, 2014
1,307
176
set region to Australia.
go into maxidot Settings and untick "diplay alternate speed"
then in the MFD where you choose what to display mpg distance avg speed etc the is a new Speed option - tick that one and you've got it.
Joe_3490
404
Had a quick look when I had 2 mins and have activated coming home lights with flick of stalk. And beep to lock
Sent from my SM-G920F using Tapatalk
Joe_3490
404
:) Carista Played with.
So I finally got round to playing with Carista now I received my adapter :funk::funk:
Here is a list of what options it allows us to change
Doors / Windows / Remote:
Auto-lock doors when moving
*YES* / NO
Auto-unlock doors when key is taken out of ignition
*YES* / NO
Auto-lock trunk when moving
*YES* / NO
Unlock trunk when doors are unlocked
*YES* / NO
Blink turn signals when locking/unlocking with remote
*YES* / NO
Beep when locking with remote
*YES* / NO
Beep when unlocking with remote
YES / *NO*
Beep when alarm is armed
*YES* / NO
Unlock doors via remote
DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND / *ALL DOORS ON 1ST PRESS*
Enable settings for opening/closing windows and sunroof
*YES* / NO
Open/close windows via long-press on remote Not Applicable on this car
YES / *NO*
Open/close sunroof via long-press on remote or key
YES / *NO*
Open sunroof via long-press on remote
YES / *NO*
Close sunroof via long-press on remote
YES / *NO*
Open/close windows by holding key in door lock
YES / *NO*
Blink turn signals when done closing windows via remote
*YES* / NO
Re-lock doors automatically if you unlock, but don't open a door
*YES* / NO
Enable remote control buttons when ignition is on
YES / *NO*
Instruments / Display / Dings:
Instrument cluster language
CHINESE / CZECH / DUTCH / *ENGLISH (UK)* / ENGLISH (US) / FRENCH / GERMAN / ITALIAN / NORWEGIAN / POLISH / PORTUGUESE / RUSSIAN / SPANISH / SWEDISH / TURKISH / NONE / SYMBOLS (NO TEXT)
Instrument cluster region (affects ext. lights too)
GERMANY / EUROPE/OTHER / USA / CANADA / GREAT BRITAIN / JAPAN / SAUDI ARABIA / *AUSTRALIA* This Option allows you to have Digital Speedo in MFD and constant outside temp displayed where KPH was
Temperature display units
*CELSIUS* / FARENHEIT
Distance display units
KM / *MILES*
Speed display units
KM/H / *MPH*
Pressure display units
*BAR* / PSI / KPA
Volume display units
LITERS / *GALLONS (UK)* / GALLONS (US)
Time display format
*24H* / 12H AM/PM
Date display format
*DD/MM/YY* / MM/DD/YY / YY/MM/DD
Consumption display units
*MPG (UK)* / MPG (US) / L/100KM / KM/L
Multi-Function Display
*ENABLED* / DISABLED
Gauge needle sweep at startup
*YES* / NO / NOT AVAILABLE
Seat belt warning
Lane-change turn signal auto-flasher
Lane-change turn signal auto-flasher count
1 FLASH / 2 FLASHES / 3 FLASHES / 4 FLASHES / *5 FLASHES*
Lights:
Daytime running lights
Allow configuring daytime running lights via dash display (cannot find anything in Dash Display)
*YES* / NO
Coming-home lights (req. auto headlights or manual flick of high beams)
Leaving-home lights (req. auto headlights)
ENABLED / *DISABLED*
Coming/leaving-home lights use…
LOW BEAMS / *FOG LIGHTS*
Coming-home lights duration
10 SECONDS / 15 SECONDS / 20 SECONDS / 25 SECONDS / *30 SECONDS* / 35 SECONDS / 40 SECONDS / 45 SECONDS / 50 SECONDS / 55 SECONDS / 60 SECONDS
Leaving-home lights duration
10 SECONDS / *15 SECONDS* / 20 SECONDS / 25 SECONDS / 30 SECONDS / 35 SECONDS / 40 SECONDS / 45 SECONDS / 50 SECONDS / 55 SECONDS / 60 SECONDS
Turn off front fog lights when high beams are on
*YES* / NO
Cornering lights (using fog lights)
Turn on cornering lights when turn signal is on
*YES* / NO
Turn on interior lights when key is taken out of ignition
*YES* / NO
Flash brake lights in emergency stopping
YES / *NO*
Flash hazard lights in emergency stopping
*YES* / NO
Brake lights work even when ignition is off
*YES* / NO
Euro parking lights when ignition off, turn signal on
Other:
Activate side mirror heaters when rear window defroster is on
YES / *NO*
Automatic wipers (using rain sensor)
Speed-dependent windshield wiper speed
*YES* / NO
Additional 'tear' wipe after windshield washer use
*YES* / NO
Auto-enable rear wiper when front wipers on and reverse gear engaged
*YES* / NO
Horn works even when ignition is off
YES / *NO*
Obtained with Carista 2.4 beta-16 for Android.
^^^^ Video of Dial Staging and Large MPH ^^^^
So far very happy with the changes,
Also played with the Torque Pro app and that's fun to play with,
ECU speed and GPs speed were very similar, but Speedo was at 30 with Cruise on.
camelspyyder
2 SEAT-er
Jun 26, 2014
1,307
176
Is it worth £45 though (software and branded OBD2 dongle) ?
I think yes.
But If I already had a compatible dongle and was only splashing out £15 then certainly yes.
Just for the central locking re-program.
Joe_3490
404
I think yes.
Agreed,
I feel the £45 for OEM and software is, as I can use it on other units too and not limited to VAG Either
Ok you don't have the same ability's as VCDS but it does what most need :) granted I have spend more like £60-£70 in total with adapters that wouldn't work but such is life, still worth it, (esp when its birthday money used) and not wasted on food/drink :)
