VCDS list / Database
Jun 7, 2006
2,983
Norfolk, Norwich
hello
is there a list vcds changes for the mk4 ibiza
i have found
To disable Auto Locks...
Turn on ignition, start up VAG-COM...
Go to "Select control module" from the main menu.
Select "46 - Central conv."
Click on "Adaption - 10"
Press "Up" next to channel number and watch for "Auto Lock" at the top.
When found Auto Lock, set "New Value" to '0' from '1' click "Test" then "Save"
Press "Up" next to channel number and watch for "Auto Unlock" at the top.
When found Auto Unlock, set "New Value" to '0' from '1' click "Test" then "Save"
Then click "Done, Go Back"
Remove key from ignition then the next time you start up those annoying locks won't bother you.
To disable Selective Unlocking...
Click on "Recode - 07"
The number in at present will be a even number, add one to that number to make it an odd number then click "Do It".
Remove keys from ignition and lock the car - the next time you go to unlock pressing the unlock button will unlock everything.
__________________
Badger
2,888
7
Newcastle, Staffs
This has reminded me.
I was making a printable PDF file with hints and tricks for the mk4 Ibiza and VCDS which was broken down with both VCDS-Lite and VCDS. I better get round to sorting it down soon...
